What memory card are you using?My firmware is lastest version,
And replaced SD card.
But,I will re-flash firmware and resetting for test again.
Thank you for support.
SanDisk Ultra? If so, not a good card to use. Very troublesome. Kingston should be OK, but have not used one in a Dome camera before.I use kingston 64GB class 10,and sandisk 32GB class 10
Thank you.
I use kingston 64GB/10,no problem.SanDisk Ultra? If so, not a good card to use. Very troublesome. Kingston should be OK, but have not used one in a Dome camera before.
My dashcam DAB201 error create year fail.
It create folder 161215000 and 170115000,record time not continue
DAB202, DAB201 and DAB205 can all use the same firmware.on 4pda.ru forum have message to the firmware version ZX-AMF-G-3099Y and link to download for version dub 205. But it has successfully put on the dub 201
I'm tested custom bitrate firmware,It stop recordDoes 3099Y fix anything or let you disable the speed from the display? I've been using the v2382 custom bitrate firmware for the past year without issues.
Memory card low speed warning and stop record.
Please explain what you mean. I am not sure what you meant.
