What is the lestest firmware of Blackview DAB201
I'm updated and test new firmware for 1 week.
Test it OK.
Thank you for support.
Not at all.... there is a time gap(3sec-6sec) between the video clips.
So is it no longer support for the Seamless loop Recording?
Does 3099Y fix anything or let you disable the speed from the display? I've been using the v2382 custom bitrate firmware for the past year without issues.
Can you post some photos of the option menu please?
Also, is there any time gap between the video clips in the v2382??
The option menu is the same and was in English after I updated to v2382. I don't notice any gaps.
Sent from my VS995 using Tapatalk
Format SD card on your desktop.
Copy and paste the .bin file to the newly formatted card.
With camera off, insert this sd card.
Turn cam on. Option to update firmware will be presented. (Yes/No)
Once firmware update is complete (it's quick) the camera will turn off.
REMOVE the SD card.
Insert a different clean SD card into the camera, or remove/format the first SD card again on your desktop.
Check all of your settings, as they will have been overwritten.
There are 2 file inside 20161021a_DAB201_A12a55_gps_zhongxing_v3099_v4_lcd_hx8268.rar
- AmbaSysFW.bin
- bst_bld_sys_dsp_rom.elf
I followed the steps but i can´t see this step: "Option to update firmware will be presented. (Yes/No)" ? I have inserted the card but nothing happens, it just starts recording.
- AmbaSysFW.bin
1.Extract file .rar (by winrar)
2.Format the Micro SD to FAT32 (Data lose)
3.Copy "AmbaSysFW.bin" to Micro SD
4.Turn off dashcam
5.Insert Micro SD
6.Turn on dashcam
https://dashcamtalk.com/dome-d201/#Firmware_Update_Instructions
Easy steps that i have already followed. It just starts recording once i turn on the camera. When i try with DirectUSB software says "Found 0 AMBA device!"
Is it possible the file extraction wasn't actually done or was done incorrectly? Sometimes this happens with MACs. Also, be sure just the .bin file is on the card. It needs to be on the root directory, not in any folder.
Есть доработанный новый вариант из одной из последних прошивок videobinforum.com
