What is the recommended micro SD card?
Whatatay
What micri SD card is recommended for the WR1?
sone983
Serbia
Yi dashcam,VIOFO WR 1
I use Toshiba 64GB micro sd card.You can use whatever card you want, I dont know if Viofo recommend any brand of sd card, but I know you should avoid San Disk for usage in dashcam generally.
Sent from my CUBOT MAX using Tapatalk
Viking
Virginia
WR1, Mini 906, 2*A119S, SJDash
I use PNY green elite
runtohell121
Thinkware X700, Viofo A129 Plus Duo, Vantrue N4
I'm currently using a Samsung 64gb Pro card in it and works fine. Just be sure to format it on another dashcam or on your computer in the right format before inserting it into the WR1... Otherwise, if you try to format it in the dash cam, it won't record. It recognizes that it's a 64gb.
