FLDJF713
So, I'm trying to determine if I should use the 2560x1080 for a wider view, or stick to HDR with 1080p. What are you all currently using?
I don't know about the mini 0805, but on the mini 0806, the mode with the narrowest field of view (greatest zoom) is the wide screen cinema mode 2560 x 1296, the other modes all have a wider field of view. So the combination of narrowest field of view and significantly more horizontal pixels gives the cinema mode significantly more dpi / better resolution and it is by far the best for reading small writing on license plates.Hi, I am new here, and don't want to start by upsetting members, but I disagree
Using the superwide 2560 x 1080 mode you are not zooming in any greater than 1080 as that's the vertical resolution. all you gain is extra width which will not help make things like reg. plates any clearer than 1920 x 1080 when zoomed.
If you use the 2304 x 1296 resolution you have more vertical pixels (and the pixel count overall is higher) therefore the clarity is (in theory) better when zoomed.
previous to coming to the above conclusion, I have been playing with the camera filming out of car as I don't have all the hardwire stuff yet. To me, that resolution looked better.
as either mode is still quite heavily compressed. Also a good point about white balance and FOV.
I assume that all the modes are scaled down from full sensor width apart from 2560x1080 which is at sensor resolution but not quite the full sensor width. No scaling gives best quality.can depend on whether they crop or compress, there's a lot of these that aren't doing things the best way
N | Resolution and HDR or not? | Mini 0805 | 1 |
Similar threads |
