minibigs
Hi. I am looking for advice on what cameras to buy (front & rear if possible) for my impaired son. His issue is he has low strength & coordination in his hands.
I have just returned a Nextbase 522 GW with an integrated nbdvrs2rfcz rear camera module, ordered from Curries in the UK. partially because the SD card they bundled with it is not U3 compliant & the unit will not record on it.
The main reason for returning it was that my son could not sit in the car waiting for 30+ minutes while data was transferred from the camera to cloud or phone via bluetooth / wifi, he could not manage removing the camera from it's magnetic mount (I found it hard to do myself, as the magnetic connection is stronger than the suction holding the mount to the windscreen, thus 9 times out of 10 you end up pulling the whole lot off the windscreen rather than removing the camera), neither could he remove the SD card from it's annoyingly located fiddly small slot. Thus he has no means of getting videos off the camera.
I would welcome any suggestions of alternative cameras to look at, that have got either easily removed SD cards, are easy to remove from their mounts, or provide other easy data transfer alternatives, but hopefully are of equal or better quality to the 522 GW.
