Resolution 12 / 10 M if thats megapixel then its interpolated pictures and you do not want to go there the camera are 2 mpixel.
Sequence on/off ???? i am not sure what that's good for.
Quality, yes you would like that to be fine, i assume this is the bitrate and you would like that to be high so fine or if its there ultra fine.
Sharpness, it should default to normal i think, strong will make the footage look a little weird.
White balance should always be auto.
Color ???? not quite sure what the options are here but you will off course want your recordings to be color. ( maybe you can select incandescent - black and white and so on but dont bother with those )
ISO, this should always be on Auto
EV is something to do with exposure, normally it range from -2.0 -----> 0 --------> + 2.0 Normally this should be on 0 and not need any changes.
Anti shaking, this are probably EIS ( Electronic Image Stabilization ) there shouldent be any need for this in a dashcam.
Quick Review ???? i have no idea what that can be.
