Yes the PRO have the 9663 chip-set otherwise it can not support the optional rear camera, and solo it can do 1080 / 60 fps on the front camera alone, and also Yes to the sensor being upgraded, its not mind boggling better then the non PRO, but every little thing count.it appears the Pro has an upgraded processor and different sensor than the non-Pro
How much of a step up is the Pro compared to the GCV3? Thanks.
What is the FOV on the SGGCX2PRO rear camera? Is it the same as the front cam?
right now anyone using the rear cam would be using the same camera that the DC comes with, we have 3 other rear camera options releasing soon so there will be a bit of variety in the spec and application options
there will be different sensor and lens options and two waterproof models, for the rear a wider view is often preferred however the same cameras will have a front application for another model we're doing so a narrower option is still needed
my car is similar layout to yours, I still like the existing viewing angle but in saying that I may also go with an external camera right at the rear to cover what gets hidden from the rear window mounted camera by the tub
yeah I have multiple cameras so having more that one rear camera isn't an issue, appreciate that that's not the norm though in which case if I had to choose between the two I'd be going for the one in top of my rear window rather than the one at the rear step for the better overall coverage resultYeah, the tailgate blocks the view of any vehicle that is very close to my rear bumper but otherwise with the camera high enough in the rear window (on the headliner) it's not too bad. With the camera in the rear window of my pick-up I find it very useful to be able to keep an eye on any cargo I have stowed in the bed as well as having coverage of either side of the bed out on the road and when parked. If I were to put a camera all the way in the rear, say on the tailgate I would also lose the full 360º overlapped camera coverage I currently enjoy with my four cameras.
