Where to download 0801-244-2212-Burning-Software.zip ??
tk1971
Links to givoe don't work.
Anyone know where I can download so I can unbrick my 0801?
Thanks.
Thanks. Got everything connected, but no go. My brick is still a brick.
Downloading the elf file results in this:
0801 elf fail by tk_1971, on Flickr
I've reset it a dozen or so times.
I just realize I need to get ready for work soon. Bummer.
How did you brick it?
Did you use the download or upload button?
I modified Fw 20130823 with chevy logos. I thought I got it. But I guess I didn't. Solid blue light after fw update and black screen.
Now I just want to get it back the way it was. 20130823 worked for me, as the fw it came with (mov files) kept shutting itself off.
Since this is only a software brick OT should be recoverable
So, I tried again this time using DirectUSB-Setup-v2.2.19.0
I set the #define PROGRAM_TIMEOUT 3000000 in the Board configuration file.
I realized that I might have pressed a button here and there and wiped out the boot loader. So, I decided to download the a2.bin file under the directory: C:\Program Files (x86)\Ambarella\DirectUSB II\bld
At least that went through so I know the cable / driver is good.
I then went to download the file: 20130905-NO1-SPI-1CARD-2710-GPS-MA310.elf
But it's taken like 10 minutes and it's still going with this screen:
stuck on elf download by tk_1971, on Flickr
The Debug log so far says:
Found 1 AMBA device!
C:\Users\tonyk\Downloads\0801\RecoveryElf\20130905-NO1-SPI-1CARD-2710-GPS-MA310.e2b sent, size=4217312
Wait firmware programming...
Set message level: 3
AMBA_Log_Set_Level.()
[2.2.19.0]
AMBA_Log_Set_Level:(2)
Set message level: 2
Set message level: 1
[2.2.19.0]
[2.2.19.0]
[2.2.19.0]
[2.2.19.0]
[2.2.19.0]
Is this a problem?
Thanks.
It's 27 minutes in and I'm getting this on the log:
Reinit start signal.
Reinit start wait.
Reinit start wait.
Reinit start wait.
Reinit start wait.
Reinit start wait.
Reinit start wait.
Is this wait related to the 300000 ms PROGRAM_TIMEOUT? If I had slipped and put in an extra zero, that's going to be like 8.3 hours.
Remove one of the zeroes, somehow your camera wont switch to LOAD mode..
Did you install the correct driver?
This driver is installed and windows states that its functioning properly:
driver by tk_1971, on Flickr
Now that I've got the boot binary loaded, I'll try the Universal DirectUSB program.
OK, doing it all over again with older DirectUSB (Universal).
First a2.bin for boot loader (AmBoot), followed by a different ELF file (20130821-NOGPS-2CARD.elf). This is the log:
Found 1 busses, 1 devices changed
bus=0, port=0
Dev#1: 0x4255 (Amba) : 0x0001 (A4 ) : 123456789ABC has 1 configs
State is BOOT
Found 0 busses, 0 devices changed
bus=0, port=0
State is BOOT
[0] Done!!
Found 0 busses, 2 devices changed
bus=0, port=0
Dev#2: 0x4255 (AMBA) : 0x0001 (Ambarella USB generic class) : 123456789ABC has 1 configs
State is LOAD
Device issuing error
bus=0, port=0
State is LOAD
bus=0, port=0
State is LOAD
bus=0, port=0
State is LOAD
C:\Users\tonyk\Downloads\0801\RecoveryElf\20130821-NOGPS-2CARD.e2b sent, size=4723168
[2.2.19.0]
Reinit start wait.
I got a green OK light:
status ok by tk_1971, on Flickr
What do I do now?
Disconnect and reset? I'm now very apprehensive about this...
Success!!!! Boots up in Russian. I'll change the language. Tobi@s... Thanks.
What was the problem? :D
unpaidbill Mini 0801 7
Nick Gilbert Mini 0801 1
