and dont forget you should have a diode, the correct way, across the relay coils to prevent any unwanted damages from spikes from relay de-energisationThe safest and most professionaly accepted way is to tap the fuse, use it as a power signal to a relay, then run a wire directly from the battery to the relay for the Ignition On wire. I'm sure this is all too complicated for you, but as kamkar said always avoid safety systems.
how about when you get out and lock it??I have an RX but have not installed my cam yet due to time constraints. I am considering FUELOPN and one of the power outlet curcuits. If you sit in your car with the ignition off you will notice the fuel door will open so that seems to be always on.
Correct?
Problem is either my multimeter is broken or I'm doing something wrong as none of the fuses read anything even if the car is on or off. I'm pressing the red multimeter pin to the fuse and black is on bare metal but I can't get any fuse to read 12v. How hard do you press into the little fuse hole?
My cars battery reads 12.08v but the fuses don't read anything even if the car is on. I must be doing something wrong
Are you touching your black lead to a bare metal ground point? You don't put both black and red into in each part of the fuse points. You only touch the red lead to the fuse.
I was touching it to metal but it might have been painted metal, I'll try to find a bare metal bolt
Thanks, got it to work on a bare bolt. But now the fuses generally say 9-10v when the engine is on.the check strap (that thing that stops your door opening too far) is usually a reliable ground point
'Usually' the owner's manual will list which circuits/functions will stay active after the ignition is turned off for a certain period of time or until something happens, like opening the driver's door. If it doesn't you may find that information in an on-line user forum for the specific vehicle....how do you know if the fuse is truly constant or shuts off after a certain amount of time?...
