Off the top of my head I cannot say exactly the name of the firmware, other than it was from Viofo and v2.61, the name now has changed and although I have formatted the card and installed another copy of 2.61 the FW shown is still modded FW. It has not gone back to the Viofo name and FW version.
I do not want to antagonize or step on anyone's toes here, it was kind of the modder to offer an option of another FW that could give me more clarity, but if that may cook my camera I would be best to keep it standard.
Thanks for using some of my A119S Modified Firmware. Always good to see owners wanting to improve image quality, your comments will help many others reading these messages. Many have already replied with accurate and useful information, want to clear up a few important points.
The A119S can handle 50Mbps Bit Rate spikes in video recordings when driving through complex pattern treed areas, this is expected and normal. The maximum modified bitrate supported is limited to 28.0Mbps but as
@CaptureYourAction said driving tree lined roads will raise the average since its variable. Many Forum members help to Beta Test MODs using the highest bitrates both for maximum image quality assessment and A119S stability, none so far have failed.
Your Dashcam works well if the basic settings are correct,
@Tractor has been helping you with that, the CPL Filter alignment can be an issue for reflections and many videos are available, mine is probably the simplest. Best way to determine best Firmware for your needs is load Official v4.00 or v2.61 then drive any road with sun behind vehicle without CPL to record short video clips, repeat for each firmware. Now download and install newest A119S MOD-6Vf or 6Nq to repeat test route. Once you review the footage and determined your favourite, install the CPL Filter (hopefully aligned, use my video) and drive everywhere in all day and night conditions. Post your best MOD footage for assessment, we can advise you then.
Based on the original MOD 7R clip you posted you are renaming and updating the modified firmware correctly. As you say its much to learn and remember, if you find my firmware useful consider becoming a Beta Tester with us, let
@Tractor or
@dacbuc know. Together we are all attempting to improve our Dash Cams, the DCTeam is here to help.
Recommend to ease your high temp concerns load MOD-4Vf but tree'd roadsides will still appear blocky & mushy to impove that use 6Vf or (6Nq-currently under development).
FWA119S_MOD-
6Vf_v4.02B+
26Mbps+Sharp506070+Edge138+DCTeam.bin
FWA119S_MOD-
4Vf_v4.02B+
24Mbps+Sharp506070+Edge138+DCTeam.bin
FWA119S_MOD-
2Vf_v4.02B+
22Mbps+Sharp506070+Edge138+DCTeam.bin
Download > https://drive.google.com/open?id=1I6hawkLiEsQSv6IamPRWkchXX3-o8j-j
FWA119S_
MOD-6Nr_v4.02+26Mbps+Sharp575860C+Sharp140B+Edge146+Brite127+Sat124B+Sat20A+DCTeam.bin
Download > https://drive.google.com/open?id=13LeOenLuh_9ThmTLNea1KUgisYeKmWU-
If you need anything let me know.
