- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Some more than others
The memory card is the weak link in any camera so can never be totally set and forget
I'm always amazed and gratified by how reliable my Mobius cameras are. This winter was long and harsh out where I live and the result was that I gave scant attention to reviewing footage from my rear and side cameras. The last thing I really feel like doing is messing with microSD cards when the temperature is well below zero and it is snowing out. When I finally got around to popping the cards from the Mobius cams when Daylight savings time came around I discovered that they had continued to hum away all winter with no problems. Of course, it helps that they have blinking LEDs to keep an eye on but best practice for dash cams is to actually confirm their operation by reviewing footage periodically.
I can't argue there. My Mobius 1 bounced off my dashboard more time than I can ever imagine and always worked perfectly. It was only when I dropped it on my tiled floor and it landed perfectly lens down, did I experience a problem. I'm sure the rubberised exterior helped a lot though. Pity they've now dropped that.
I keep wondering how long we have to wait for SSD tech to replace micro-sd cards in dash cams.
my mobius 1 has sensor issues after running nonstop in almost a year at highest bitrate. But it's still very amazing with a tiny cam only cost 100$.
( I live in a tropical climate city)
PS: the image begin blurry. I did try to re-focus the lens but it doesnt work.
i still have 3 - 5 more to go. Mobius is very hard to sold in my market.Running like that in those conditions will eventually take a toll on any camera
i asked for lens but they (china seller) only sell both sensor and lens. The cost was around half of new mobius. That's ok. Only a testing. I still have plenty to useSounds like the sensor or backing plate may have warped from the heat. The thing with the Mobius is that if you pop in a new lens module you would likely be right back in business with the camera and you'd be good for another year of full time service.
Hopefully not in the short term!
The problem with internal fixed memory is all memory chips have write limitations in terms of the number of times they can be written to after which they degrade and blocks of memory start to fail causing loss of data. With a dashcam you are writing to the memory continuously so it's only a matter of time before the memory fails. With an SD card, you simply throw the card away and buy a new card. With an SSD with flash or DRAM memory, either the whole camera would have to be trashed as the memory would be fixed internally, or if you could replace the memory yourself, either by design or your own skills through it being plug and play internally and not soldered, the replacement memory itself is going to be far more expensive than an SD card as SD flash can be manufactured far cheaper. I also think, but am not totally sure, that SSD's require more memory controller functions and as the memory controller is mounted on the SSD board, this again is likely to make it more expensive. Whilst SD cards do have a small onboard controller, I believe a lot of the functions are in the camera itself in the form of the card reader. SD cards are also designed to be robust and sustain being inserted / removed. SSD's aren't as robust in this regard.
So basically, whilst an SSD is more suited to repeated read / write operations, it is still going to wear out and will either cost you a new camera or more money to replace if it's replaceable.
I guess the holy grail would be if someone could come up with a DRAM SSD that is small enough to be plugged in like an SD card making it removable and cheap enough to be replaceable. That would overcome the poor lifespan issues of some flash cards and hopefully the compatibility issues through a standard memory controller as with pc's.
However, I rather think the real answer in the short term is for SD card manufacturers to actually come up with dashcam specific cards that can take the constant write cycles and don't have the controller issues we seem to be seeing with some cards as I don't see an SSD being competitive or available short term.
You being a retailer should be able to get for less.
Yeah. That happen when a camera almost dont need warranty. People simply buy online from the manufacturer with the cheapest price.don't count on it, their wholesale price for the whole camera to the resellers is only $8 less than they retail it for
No, higher bitrate means less compression hence less processing power which should mean less heat at the processor chip. The heat at the sensor itself is the same because the sensor captures a raw imageHigher bitrate equals higher heat at the sensor. I run the 'normal' bitrate on mine and even in the high summer heat here, I've had no problems at all. I'm still getting good images so I'm leaving that setting where it is.
