- Sep 5, 2018
- China
- AZDOME M06P Real 4K Dash Cam
If the dash cam SD card can be read on the computer, it means the dash cam has some problem, you can take it out to format. So I suggest that you buy a good quality dash cam. Although without the high requirement of technology, the hardness of the requirements are relatively high, especially the use in a relatively bad environment, so stability is the biggest test for many manufacturers.
If switch off the electrical power or appear the machine error, it can’t form a stander video file so that it can’t be played normally. Another is caused by a false memory card that the low-capacity cards brushed into high-capacity cards on the market when it is normally used that this card memory less than his actual capacity of the file, but Larger than its capacity, you can see the file but can’t be open and copy.
Why does the dash cam video have no sounds when playing? It may be your computer don’t have an audio decoder, so you can try a few players.
