Why does the red light flash randomly?
country_hick
Why does the blinking blue light sometimes flash alone and other times the red light blinks?
It has done this with 2 class 10 cards from Kingston and pny.
Does it affect the files?
Have you tried to reinstall the firmware?
Do you have motion detection on?
I tried the original and Romanian firmware.
It happens with both versions.
Recording seems to happen uninterrupted.
I was using the romanian version firmware without the viofo startup screen.
I got the same results from the original firmware with the viofo startup screen.
I had the G sensor set on low.
HDR was on.
Motion detection off.
The red light blinking happened even when my car was sitting still.
I included video of the blinking light suddenly changing color in the link below. Boring, but shows the issue.
https://dashcamtalk.com/forum/threads/is-this-g1w-s-defective.31251/
The camera also has a ton of static and the audio is barely audible. An example is here.
https://dashcamtalk.com/forum/threa...-on-more-light-suddenly-being-available.31013
Done just a few minutes apart.
Low volume lots of static Romanian firmware
Low volume lots of static viofo original firmware
@viofo Do you have any ideas? Why is the audio full of static and the red light flashing intermittently?
