- Mar 22, 2017
- Caerphilly
- United Kingdom
- Nextbase
Movement of the vehicle should wake the camera up.
Please perform a Parking Mode test:
1) Plug the camera in using the USB cable. Ensure the Blue LED is illuminated and that the cam is receiving power.
2) Make sure the cam can record, you may need to select 'POWER ON' on the screen if plugged into a PC.
3) Ensure Parking Mode is turned 'ON'.
4) Put the camera on a flat, still surface.
5) Press the record button. The camera will start recording a normal file.
6) Now leave the camera still. After a period of inactivity, the camera will turn off.
7) Once the cam has turned off, shake it.
If the camera turns on and records with a padlock on the screen, Parking Mode is functional.
Kind regards,
Millie
Nextbase Technical Support
Kind regards,
Millie
