Wifi issues after iOS 13 upgrade
NutVaccine
London
It sounds like this is an issue that has been posted before, but I still haven't found the solution for the recent WiFi issues.
I have a Nextbase 312GW which used to connect to my phone via the Cam Viewer app. However, phone has changed since and is now running iOS 13.2.3.
I have updated the dashcam to the latest firmware R06.9 and Cam Viewer to 2.3.5.
The phone connects the the 312GW's wifi and says it's connected. I've tried turning off Mobile Data. BUT in the Cam Viewer app it says "No connection found" and you can't see the videos.
It still works via the cable to the PC, but half the point of this dashcam is that you dont need to keep connecting it to the computer!
Anyone have any clever ideas?
Thanks.
Rickn55
England
Nextbase 612 4k, 522+rear window cam, 322+rear view cam, 312
Thanks.
This isn't anything new tbh. I've always found the Cam Viewer App for the 12 series very hit or miss with this problem over the years with all devices I've used. Either getting the not connected screen or being half way through looking for your file or half way through downloading the selected file and the connection being lost.
However the new App for the latest 22 versions is flawless and works perfectly.
Sent from my SM-T580 using Tapatalk
NextBase Support
Caerphilly
Nextbase
Thanks.
Hi there,
It sounds like the Bluetooth Connection has been lost. I'd recommend:
Restarting the phone and Dash Cam.
If it still does not connect, please follow this procedure:
1) Turn on the Cam
2) Stop it recording
3) Go into Settings by pressing the menu button twice.
4) Scroll down to 'Default'
5) Follow the instructions to default
6) On your phone, please uninstall the CamViewer app
7) Go into your Bluetooth settings on the phone, then delete any connections you can see to NEXTBASE
8) Go into your Wi-Fi settings on the phone, then delete any connections you can see to NEXTBASE
9) Re-install the CamViewer app
Once steps 1-9 have been followed precisely, please re-pair the phone and the Dash Cam. The phone and Dash Cam should then successfully reconnect.
Regards,
Millie- Nextbase
twin-k84 312GW 7
Similar threads
312GW wifi problems
