The dashcam records perfectly, but will never find GPS. The GPS symbol flashes on and off continually, even after an hours open country driving.
Hi Adrian,
1. I'd recommend ensuring that the cable is plugged in to the mount, and not directly into the camera. If it's directly into the camera, the camera will not receive GPS information.
2. On the Dash Cam's screen, there should be a GPS icon in the bottom right. If it's flashing, then the GPS is being detected, but cannot be connected to.
3. Please ensure the connectors between the GPS mount of the camera are clean, free of debris and undamaged.
4. Please take your mount and camera inside a house and attached it to an outer-facing window that has a clear view of the sky. Then connect it to power using the USB cable. Does the camera now show the GPS icon or any GPS information?
5. I'd recommend checking that your Camera is on the latest Firmware available. It should on R22.8.
If you complete all of the above and you still can't get a GPS signal, the GPS mount is likely to be faulty and the mount needs replacing. Please let me know if this is the case.
Kind regards,
Millie
Nextbase Technical Support
