Wrestling the 522GW off the mount
grajay
Shropshire
I have looked everywhere on the net so I guess there must be a technique form pulling the 522GW off its mount. Sometimes it comes off easily other times I nearly pull the windscreen into the car. I've also heard a 'click' from the 522GW almost like something has disconnected - then the camera comes off the mount. Does anyone have the secret please? Thanks
Hi Grajay,
To remove a camera from it's mount we'd recommend holding the mount (with your thumb and index finger) against the windscreen, whilst pulling the camera straight back away from the mount. If you pull it at any angle, it will resist against the bracket and so make it harder to remover. The magnets are fairly strong to ensure that the camera will not dis-attach from the mount in the case of an accident.
I hope this helps.
Regards,
Millie- Nextbase
Thanks for the tip. I must confess that I was probably a bit tentative in case something broke.
