SawMaster
- Apr 10, 2015
- SC
- Numerous and ever-changing
I'd be pulling my hair out right now but I don't have any to spare. JooVuu replaced my old cam with a new one and I'm still getting nowhere. Now before you suggest I go to the JooVuu forums that didn't help before and it won't help now so it ain't gonna happen. This will get sorted right here for all to see (and not by just a few over there).
I bought a new Transcend 64GB card of the 300x Class 10 recommended type. It was formatted to FAT32 in my Mobius as W8.1 won't run any of the card formatting freeware, The card works perfectly in Mobius and G1WHc cams so the card is good. Don't suggest another card; I've been down this road before and that ain't the problem.
I opened the card on this laptop ("J" drive) and deleted the existing files, folders, everything I downloaded the latest firmware as .bin and 'sent' it to "J" drive and on checking it had been transferred. I put the card in the cam and plugged it into my 2.5A wall-wart PS with a known good cable which works with every other cam I've got so don't suggest a new cable or PS; I've been down this road before and that ain't the problem.
The cam gives a solid green LED then the wifi LED begins flashing blue as it is supposed to. 10 minutes later it's still flashing blue. I unplug the cam and a few seconds later the lights dim and stop. I put the card in the laptop and delete the files, then I download the oldest firmware as .bin and get the same results. I try again but this time with newest firmware in .elf and it opens with VLC player which shows an error. Ditto for .elf on the oldest firmware.
I've followed the posted instruction to the letter, double-checking everything to be certain I'm doing nothing wrong. I tried an in-cam card format but it won't switch to standby mode so that's no good. I tried a reset to no avail
After going round and round with the first cam which also did this I was too PO'ed to fool with it after the replacement was sent for so long that it's out of warranty now. It's the longest odds in the world that both cams I got were duds so either I'm doing something wrong or JooVuu is doing something wrong with the PC-based program. I honestly don't know which. I checked out the "Unbricking" thread on the other forum but for the life of me I can't understand how to use it.
I need someone who will take me through the process of making this cam work with this W8.1 laptop as my only input one step at a time with each step verified on my end as working correctly before we go to the next step. That way whatever the problem is will become apparent and it can be fixed to get me to a working cam. I'm not a techie, just a casual PC user so please be explicit about how to do things.
I'm truly at my wits end. I can make Mobius work, I can make G1Wc and G1WHc work, so I can't understand why I can do that here.
