Guys, "usleep ms" works great, don't make it so complicated 🙂
t gpio 6 sw out1
usleep 400
t gpio 6 sw out0
t gpio 6 sw out1
usleep 400000
t gpio 6 sw out0
I was playing with beeps after telnet session and it worked for me, but now I can't reproduce that. So I guess it doesn't work with default settings, sorry for misinforming.Can you give an example script? Usleep doesn't work for me.
it just outputs
-ambsh: usleep: command not found!
Thanks for @funnel
I test with Yi Cam to play the Jingle Bells rythom
attached the autoexec just for fun
you can desolder some LEDs 😀
Hi, @intoi, what's this use for? wifi enhancement?Aren't flex cables made of high temp material? Similar to a Kapton tape?
And by the looks of it, LEDs can easily be desoldered.
intoi, can you provide example of that cracking noise? Most preferably in as silent room as possible so only the cracking will be recorded.
Try these situations:
• wifi off, camera stationary
• wifi on, camera stationary
• shaking the camera in hand
believe it or not, but i have quite good ears and i may be able to tell whats causing it. I should receive my camera soon, but since this is intermittent problem, i may not have it.
