Xiaomi YI do not start.
pisiorek
Likes
1
Poland
#1
Hello everybody. I have a problem with camera YI Z26L , which is showed on this video :
Does anybody know solution for this problem, or should I send it to the service ?
TwoBlues
Likes
195
Eastern Shore, Md.
My international yi cam won't charge with the battery removed.
I experimented with my original z21cam and killed it. I bought an international Yi and found the battery is thicker and the door is thinner -in order to use my old batteries I used the old door and the original batteries. If I want to use the international cam battery I also have to use the international cam door , otherwise there is intrrmittent or no contact.
Might your problem be similar?
P
pisiorek
Likes
1
Poland
#3
Thanks a lot for your answer. I have original battery and additionally external charger, I made voltage measurement and battery is full, so it must be other problem. But problem with connection between battery and connectors in cam I noticed too, even with original cam and original battery, to fix this problem I put little part of paper between door and battery, it helps too.
TwoBlues
Likes
195
Eastern Shore, Md.
I have read on this forum of some owners who carefully re-adjusted the contacts in the battery box- also one owner of an original Yi said one of the contacts in the camera needed re-soldering! Any of these fixes would need great care in remedying. ' hope you solve your difficulty!
P
pisiorek
Likes
1
Poland
#5
Ok, I must find some electronics specialist, re-adjusted connectors do not help, maybe re-soldering fix my problems. Thanks.
Similar threads
