Yi 4k+ bitrate mod and firmware unpacker.
Discussion in 'YI 4K+ Action Camera' started by irungentoo, Sep 17, 2017.
  1. wpacket
    wpacket New Member
    8
    8
    Country:
    Italy
    awesome find irungentoo!!
    I'll try to contribute a bit now, maybe it gets finding other things easier ;)
    Here is the function you are patching, the pseudo c code with some renamed functions :
    Code:
    int __fastcall AmpEnc_SetSystemClock(_WORD *a1, int a2, int a3, int a4, __int16 a5, __int16 a6, __int16 a7, __int16 a8, int a9, int a10)
      _WORD *v10; // r4@1
      int v11; // r0@1
      int v12; // r5@1
      char _ZF; // zf@4
      char v14; // zf@7
      int v18; // r1@17
      int v19; // r2@17
      int v20; // r2@25
      int v21; // r3@25
      int v22; // r4@25
      int v23; // r0@26
      int v24; // r2@26
      int v25; // r3@26
      int v26; // r0@26
      int v27; // r2@26
      int v28; // r3@26
      signed int v30; // r0@32
      int var_CC; // [sp+8h] [bp-CCh]@17
      int var_C8; // [sp+Ch] [bp-C8h]@17
      int v33; // [sp+10h] [bp-C4h]@31
      signed int v34; // [sp+14h] [bp-C0h]@31
      signed int v35; // [sp+18h] [bp-BCh]@31
      signed int v36; // [sp+1Ch] [bp-B8h]@31
      signed int v37; // [sp+20h] [bp-B4h]@31
      signed int v38; // [sp+24h] [bp-B0h]@31
      signed int v39; // [sp+28h] [bp-ACh]@31
      char v40; // [sp+AFh] [bp-25h]@31
      v10 = a1;
      _ZF = a1 == 0;
      v11 = *a1;
      v12 = v10[1];
      if ( _ZF )
        print_to_log(0x5C9F44, 0x71A164, 0x3C0, a4);// K_ASSERT at %s %d
        sub_1E8DD0();
        __asm { CPSID           IF }
        while ( 1 )
      if ( !a3 )
        print_to_log(0x5C9F44, 0x71A164, 0x3C1, a4);
        sub_1E8DD0();
        __asm { CPSID           IF }
        while ( 1 )
      if ( !a4 )
        print_to_log(0x5C9F44, 0x71A164, 0x3C2, 0);
        sub_1E8DD0();
        __asm { CPSID           IF }
        while ( 1 )
      _ZF = a6 == 0;
      if ( a6 )
        _ZF = a5 == 0;
      if ( _ZF )
        goto LABEL_41;
      v14 = a8 == 0;
      if ( a8 )
        v14 = a7 == 0;
      if ( v14 )
    LABEL_41:
        print_to_log(0x5C9F44, 0x71A164, 964, a4);
        sub_1E8DD0();
        __asm { CPSID           IF }
        while ( 1 )
      if ( !a9 )
        print_to_log(0x5C9F44, 0x71A164, 965, a4);
        sub_1E8DD0();
        __asm { CPSID           IF }
        while ( 1 )
      if ( !a10 )
        print_to_log(0x5C9F44, 0x71A164, 966, a4);
        sub_1E8DD0();
        __asm { CPSID           IF }
        while ( 1 )
      v18 = v10[2];
      v19 = v10[3];
      var_C8 = 1000000 * v18;
      var_CC = 1000000 * v19;
      if ( v18 == 2 )
        v30 = sub_4C29C4();
        v19 = v10[3];
        var_C8 = v30;
      else if ( v18 == 1 || !v18 )
        var_C8 = 1000000 * v11;
      if ( v19 == 2 )
        var_CC = sub_4C28EC();
      else if ( v19 == 1 || !v19 )
        var_CC = 1000000 * v12;
      print_to_log(0x71A404, var_C8, v19, 0);       // [Desire]IDSP   freq: %d
      print_to_log(0x71A41C, var_CC, v20, v21);     // [Desire]Core   freq: %d
      v22 = AmbaPLL_SetOpMode((int)&var_CC);        // function at : 0x4C2E6C
      if ( v22 )
        v40 = 0;
        v33 = 'abmA';
        v34 = '_LLP';
        v35 = 'OteS';
        v36 = 'doMp';
        v37 = ' )(e';
        v38 = 'liaf';
        v39 = '!de';
        v22 = 4294967295;
        print_to_log(0x71A254, (int)&dword_65CC6C, 0x71A164, 1082);// AmbaPLL_SetOpMode failed!
                                                    // 71a164 : AmpEnc_SetSystemClock
      else
        v23 = sub_4C29C4();
        print_to_log(0x71A450, v23, v24, v25);      // [Actual]IDSP   freq: %d
        v26 = sub_4C28EC();
        print_to_log(0x71A468, v26, v27, v28);      // [Actual]Core   freq: %d
      return v22;
    Yes, it isnt just luck, this function is called AmpEnc_SetSystemClock, it relies on an internal function called AmbaPLL_SetOpMode, which I think it's the actual function changing the freqs.
  2. wpacket
    wpacket New Member
    8
    8
    Country:
    Italy
    It was too long to include here, so here the link https://github.com/wavepacket0/Xiaomi_Yi_4k_Plus/blob/master/research/function_names_1.3.11.txt
    This is the internal function names dump, in which you can find AmpEnc_SetSystemClock also.
    Just go where the dumped k_assert address is and rename the function belonging to that address as the dumped name.
    Example for AmpEnc_SetSystemClock : K_ASSERT found @ 0x45D5EC -> 0x71A164 -> parent K_ASSERT function name :AmpEnc_SetSystemClock
    Go to 0x45D5EC, which is belonging to function 45D588, which is AmpEnc_SetSystemClock
    Knowing this, we can better focus the attention on particular functions and also be able to patch the way they works
  3. irungentoo
    irungentoo Member
    30
    27
    Country:
    Nice, that might be very useful.
  4. wpacket
    wpacket New Member
    8
    8
    Country:
    Italy
    Later I will update the fw toolkit to also dump where every string passed though the log function is referenced in the code
  5. irungentoo
    irungentoo Member
    30
    27
    Country:
    https://github.com/irungentoo/Xiaomi_Yi_4k_Camera/tree/master/4k+/increased_framerate
    4k@70fps works when I overclock the dsp/core slightly.
    Now I need to figure out why it's making this error when I try increasing it to 75fps.
    [CORE:th6:104986] Assertion failure at /h2/work/ssyeh/default/branch/xiaoyi_Z18/ucode/src/orccode/vproc/vproc_prep.c:5919:
    [CORE:th6:104987] VPROC[chan_0]: run out of PREV_C FB
    Which looks a lot like the error when I try increasing the 1080p mode to 180fps
    [CORE:th6:338656] Assertion failure at /h2/work/ssyeh/default/branch/xiaoyi_Z18/ucode/src/orccode/vproc/vproc_prep.c:5034:
    [CORE:th6:338657] VPROC[chan_0]: run out of WARP_MCTF FB
    alex69rus likes this.
  6. retynol
    retynol New Member
    6
    Country:
    Russian Federation
  7. irungentoo
    irungentoo Member
    30
    27
    Country:
    I don't think they will ever be added because the sensor doesn't officially support hdr.
    Mtz likes this.
  8. retynol
    retynol New Member
    6
    Country:
    Russian Federation
  9. irungentoo
    irungentoo Member
    30
    27
    Country:
    If you look on the sensor summary pdf, you will notice that there is nothing on it that suggests that it supports hdr. For photos I'm pretty sure there's a way to write a script that takes multiple pictures with different exposures in a row that you could then combine after into an HDR picture but for video I don't think so.
  10. retynol
    retynol New Member
    6
    Country:
    Russian Federation
  11. irungentoo
    irungentoo Member
    30
    27
    Country:
    These are likely just default modes in the code for the H2 chip. The HDR modes don't have any corresponding sensor modes so there's no way to make them work.
  12. retynol
    retynol New Member
    6
    Country:
    Russian Federation
    10bit video yours is also impossible?
    it turns out that besides raising fps and bitrate, nothing from the camera can be pulled?
  13. irungentoo
    irungentoo Member
    30
    27
    Country:
    Looks like there's a new beta firmware out: 1.3.18. Mods have been updated for it.
    Maybe, I don't know.
    There's plenty of other things that could be modified.
  14. retynol
    retynol New Member
    6
    Country:
    Russian Federation
    where to download beta ?
  15. irungentoo
    irungentoo Member
    30
    27
    Country:
  16. retynol
    retynol New Member
    6
    Country:
    Russian Federation
Share This Page
