I have bought a new Yi mirror dashcam, but it doesn't work. I can connect to this device with Yi Dashcam Android application via wi-fi but I cannot format microSD card and this message appears on the touchscreen:
"To optimize the performance of the memory card.
It is recommended that format the micro SD Card."
When I tried to push the OK button on the touchscreen, the equipment does not react anything. When I issued the "Format SD" command on the mobile application this action starts but the result is "Format failed".
The factory reset is working at first sight run when I issued this command on the mobile application, but nothing changes after this action.
I tried four differing micro SD card with FAT32 file system. All of them made by other manufacturers. I used micro SD with 8 GB, 16 GB, and 32 GB capacity, between them the Samsung EVO+ 32GB C10 which is the mainly recommended type for Yi dashcam.
Do you have any idea what do I do?
