lufa6977
- Jul 22, 2024
- Virginia, Shenandoah Valley
- Vueroid S1-4K, Viofo A129 Pro Duo, A229 Pro, IR, Telephoto
My harness came with fuses already on the ends, plus an inline fuse on each wire. Vueroid does the same, with the inline fuse. In my view, the inline fuse is a real waste, since we are already fusing at the fuse tap. Those inline fuses can make it harder to pull the wire in (in some instances) and generally take up space in an already confined area. With the fuses on this DDPAI harness, they will not work in my fuse box, so they will get cut off also. I am going to cut out the inline fuses also, as the area is getting tight around the fuse box. I wish manufacturers would stop putting these fuses on. 🙂
My headliner - yep, that is going to require me to pull out an existing cable, I think. There is actually very little room in the headliner at the top of the windshield to hide the wires in. I think I have reached the max I can stuff in there.
