merlin said:I have one of these which is nuking the microSD cards because apparently the 3.7v 40mAh battery is dead. I'm having trouble finding a replacement. Anyone know a good source?
merlin said:Thanks for the links Dash Cam Man. I was hoping to avoid getting it off Ebay because Australia Post regard these batteries as dangerous goods and refuse to delivery them if detected. Stuff from SE Asian tends to be scrutinized more, which is probably why the guy selling the 90mAh and 150mAh batteries, kadelyltd, won't ship to here. However, I'm tempting fate and ordering from your second link.
Rehan said:I have a GS600 that seems to show a "No Card" error message 99% of the time, even when the power cable is plugged in and I insert a microSD card that is known to be working. Once in a blue moon it works, but that's very very rare now.
Is this an issue that would also be fixed by replacing the battery?
How did you determine that size?DashCamMan said:Note that the maximum space available for the battery is 35x17x5.5mm.
Rehan said:How did you determine that size?
I measured the OEM battery and it's about 20x13x3mm. Even the exterior of the GS600 casing is less than 30mm high. I don't see how 35x17x5.5mm could fit in there.
GS600 - a couple of questions | Dash Cam Discussion | 4 | ||
GS6000 Ambarella A7 Super HD 2304*1296P 30FPS GPS WDR | Dash Cam Discussion | 22 | ||
GS600, GPS Logger A2S60 5Mpix 1/2.7" CMOS | Dash Cam Discussion | 3 | ||
DOD GS600 Firmware update | Dash Cam Discussion | 0 | ||
DOD GS600 | Dash Cam Discussion | 1 |
