RustySpoons
- Jul 4, 2014
- United Kingdom
Hi,
Just put this archive together with a correctly modified autoexec.ash if you want to backup your exisiting firmware, DirectUSB modified by myself for A7 and removed any parts not needed, also included original E-Prance 2 Card GPS Rom.
Make a cable with Pin 4/5 shorted on micro usb or use a OTG cable with male to male usb plug,
Extract the archive you have just downloaded,
Plug mini 0803 in to PC, it should make a sound to say new hardware plugged in, or an unknown device appears in device manager, (If it doesn't, unplug device and hold power button for 20 seconds till light goes out and plug back in) on windows 7 manually install the drivers, point to the folder you have just extracted, then go to mini0803/DirectUSB/Drivers
Let it install, then install the C++ distribution packs for your OS.
Run Direct USB
Click connect, make sure it detects device and says init dram ok.
Select relevant firmware file under firmware (I have included one for dual card with GPS), then click Upload, it should all go smoothly, this process is quite quick, as soon as it stops doing the flash it will show a full green bar and OK.
Unplug mini 0803, hold power till blue light goes off, then turn it on and it should boot up...
Files here:
http://www.mediafire.com/download/o2rr1qi5wq5c3wz/Recovery__Backup_RustySP.7z
Run Direct USB
Files here:
