- May 1, 2013
- Dublin
- Ireland
Korean manufacturer FeneDigital is preparing to release a new model of a two-channel Dash Camera FineVu CR-2000S. It is known that this novice will record video in Full HD quality at 30 frames per second per each channel. More detailed specifications are not yet known, the appearance on the market of the DVR FineVu CR-2000S is expected in late December 2013.
![FineVu_CR-2000S.jpg FineVu_CR-2000S.jpg](https://dashcamtalk.com/forum/data/attachments/2/2180-f175f97d18c3e101824560d176d43289.jpg?hash=8XX5fRjD4Q)
Added 07 / 12 / 13
Below added more info after announcement on navinside website
I used a Google translator, so there might be some grammar mistakes in my translation.
Looks like it will be available in white and black.
![2.jpg 2.jpg](https://dashcamtalk.com/forum/data/attachments/2/2241-21b03752be87935cce537f87d022d0ea.jpg?hash=IbA3Ur6Hk1)
![7317316888.1.20131206151642.jpg 7317316888.1.20131206151642.jpg](https://dashcamtalk.com/forum/data/attachments/2/2242-21cd456c8b2f5f7f7ed0e37c52e7fef1.jpg?hash=Ic1FbIsvX3)
Features:
- the first in Korea front / rear camera with Sony CMOS Sensor
- Front-to-back set of the individual brightness crisp picture quality possible even at night
- all scenes are recorded in real-time over wide 3.5-inch LCD screen can be viewed.
- number-plates readings and other things improved dramatically ZOOM distinctive features intact while applying a clear picture can be taken to expand.
- also, do not lose clarity in backlit situations blue filter applied to high-resolution camera with WDR function level implementation.
- recording is possible in addition to start-up and at the same time to make the initial boot-up time less than 15 seconds to boot to enable quick implementation reduces the Real Time OS and does not want to delete the image can be moved aside my folder, etc.
- Sony CMOS Sensor First I / rear is equipped with all the lack of illumination at night were vivid picture quality.
- shooting angle of 115 degrees horizontal field of view, distortion-free wide visibility even at night
- also Dual memory card support for SD card more driving and parking where video images can be stored on a memory card separately. Main use of recording capacity can be adjusted and stored.
- Battery power is low power design at the front and rear camera and LCD operating at their maximum power consumption of only 4.5W.
From my post #7 picture can see GPS symbol on top of the device, so I assume that this series will also have GPS logger function, which was not mentioned in the announcement. I hope it will be built-in GPS antenna ( we will see ).
Finevu CR-2000S 'the ▲ 16GB 369,000 원 won ( 350USD ) ▲ 32GB 399,000 ( 377USD ) basic package includes a main body, holder, car cigar Code, Micro SDHC Card (16GB or 32GB), ( www.navinside.com )
Added 07 / 12 / 13:
According to navinside.ru website below are confirmed Specifications:
This recorder is equipped with premium sensor from Sony 2.4px technology to support WDR (wide dynamic range), and it is both cameras have a matrix, unlike other Korean competitors.
Features:
Some fresh YouTube videos:
Below is so called "security warning LED" video which can be turned off:
Added 07 / 12 / 13
Features:
Added 07 / 12 / 13:
Features:
- Supports WDR to lighten dark objects and dimming illumination, software Blue Filter
- Dual SD card - Supports two slots microSD and SD, the second card is written in the mode of all videos PARKING
- Diagonal Angle of view is 136gr
- Built-in GPS receiver
- Memory Cards Toshiba Exceria 30mbit/s
- Connecting cable microUSB between cameras
- Built-in protection against overheating and cooling
- Consumption of only about 4.5-5W
- Records in FullHD-FullHD resolution at 30 frames per second per camera, which is a very decent results. In addition, the company is the first DVR with screen LCD, 3.5 inch, with which you can configure the settings, and view recorded videos
- Outer side has a circular light emitting diode which can be turned off if necessary
- But there was a "big surprise" when Finevu announced first release will have front camera unit in white ( mikly colour ) and rear in black. ! This colour scheme, as shown, is very controversial. But we are confident that it will soon be released and model in black, as is usually the case with this brand.
