Firmware 0507 with changes (Without sounds and better LDWS sound)+Spanish version
Jonatan
Spain
Hello, I created new customized versions based on requests from users.
Modifications: New LDWS sound with more DBI for can listen, different start/shutdown logos, version with sounds muted (except LDWS, but only sounds if is enabled)
All version are based on 0507 from E-PRANCE and support 8GB internal memory (Too work without Interla memory).
(All files are uploaded on mediafire)
English:
With sounds: http://goo.gl/rswb91
Without sounds: http://goo.gl/UViJQP
Spanish (Español):
With sounds (con sonidos): http://goo.gl/tGaV7M
Without sounds (sin sonidos): http://goo.gl/q5yOYZ
Thanks to Tobi@s for the help and for A7tool
I test all versions on my Ambarella mini 0803 with internal memory 8GB, and Tobi@s test this firmware on Ambarella mini 0803 without internal memory and work fine, you can check this info on this message: click here for read )
(I test the firmware 0510 what don't have support for internal memory and work fine but don't work internal memory 8GB, but after re-install firmware 0507 work fine my internal memory 8GB).
(I only modify the sounds+logos for English versions and sounds+logos+texts for Spanish versions)
(I don't know modify others parameters) (But I want learn).
Neither I nor the creators of the official firmware or tools we are responsible for any damage that may result if you use any firmware you do so at your own risk.
Regards. :)
Thanks for taking the time to do this, the manufacturer doesn't seem interested in fixing issues so I guess it will be up to individuals such as yourself to help all of us.
Will this with with versions without internal memory?
All I can tell you is that Mini 0801 without internal memory had problenms with internal Memory Firmware. But you could try modifying the Sound yourself ;)
I think so, I'm still waiting for someone to try on the camera to confirm correct operation
Maybe with 0803 work fine, on my ambarella mini 0803 with internal memory 8GB work fine the version what only support microsd memory.
If work fine on two models no need to change another firmware.
You know if the strings.bin files are equals on the two firmware versions?
Regards.
strings.bin is the same. It is even the same on A2 platform. (but offsets may differ on different Firmware Versions numbers)
Non-internal Memory works on 0801 internal Memory as well.
The Problem with internal Memory Versions is that the dashcam tries to Mount the internal Memory but it does not exist.
@Jonatan: Would be great if you can provide a patched English version for 0803 without internal memory.
I'd love to use my 0803 without these nasty startup and shutdown sounds. Thank you!
If you remove the startup sound, you will never know when the cam freeze at start ;)
I just checked this: Dual memory firmware works with external-memory-only 0803s :D
If you flash 20140507 2cards fw you'll get WDR and 1296p recording.
Hello ";);););););););););););)" haha.
My camera never are freeze at start and I can see very fine the blue led for check what are recording, My camera start recording when I start the car.
But to me the sounds do not bother me, so I have the version with sound.
Simply if you have no view of the camera, use the firmware with sounds.
Thanks you for test!, I update the info of the first post, do not know what we would do without you in this forum with our mini ambarella 0803 haha.
Regards.
Good morning, everyone!
I'm new to this forum, so please forgive me if I ask some stupid question.
I just bought a couple of 0803's. My two cameras with GPS, have 8 Gigas internal, plus 32 Gigas micro sd card. Bought from from E-Prance, OEM firmware 20140507.
I have a few questions:
1- What do you mean by "20140507 2 cards fw"? Does it mean, internal memory X Gigas plus Y Gigas SD Card?
2- Which custom firmware from http://dc.p-mc.eu/0803/firmware can I use?
3- Or... Which of your (español-inglés) customised versions can I use?
4- Any step by step, detailed instructions or user manual for using A7Tool?
Thank you!
Thank you!
Hi.
1, Are compatible with two models (with or without internal memory)
2, I use the firmware from E-PRANCE, you can use the firmware what you like, if no work fine you can reinstall other firmware.
3- If you want Spanish then choose Spanish if you want English then English :P.
4- Tobi@s have a post with instructions.
You're welcome, regards.
