Thats the Problem. A7 Firmware contain a Partition called HAL. You did not extract it. Please add hal after bld:Probably wrong extracted?
I use this autoexec a leave cam approx 20 minutes.
rm a:\autoexec.ash
firmfl gen 5 bst bld pri rom dsp d:\backup.bin
rm d:\autoexec.ash
rm a:\autoexec.ash
firmfl gen 6 bst bld hal pri rom dsp d:\backup.bin
rm d:\autoexec.ash
This one is working. Please remove the other 2 links leading to the broken binaries.Newly extracted with hal.
http://www.ulozto.net/x2Fcgf6z/mini0803-nointernal-withgps-20140611-v1-xfather-zip
I just checked it: The only difference I can find is that it keeps the disabled-audio setting!What fixes and enhancements does this fw contain? Any improvement on being able to turn off startup sounds and does the mute now function correctly?
Thats good but also disappointing that a simple thing like disabling startup sounds is still not a config option.I just checked it: The only difference I can find is that it keeps the disabled-audio setting!
good to see that's finally sorted
