Hi all,
long time reader here, but just signed up to ask for help... I've previously found lots of useful advice on here, but this problem I cannot find a solution to...
I was getting bad FM radio interference with the standard power supply, and thanks to these forums I found that replacing the PSU can solve the problem, however...
It seems that the unit doesn't charge when it's recording with any other PSU: I've got a Belkin 1A car-usb adapter, and I thought it might not being giving enough power, so I bought a genuine Griffin one: https://www.amazon.co.uk/gp/B0042B9U8Q I know there are a lot of fake ones of these around, so I bought from Amazon direct, and am confident this is a genuine one... however, it still doesn't seem to charge it when it's powered up.
This non-charging of the cam causes the battery to quickly die, and then after a couple days driving (short trips) the cam starts going nuts, powering on and off when driving and creating corrupt video files.
Normal behaviour with original PSU: Turns on, has a purple light, which I believe is the red light showing it's on, and the blue light showing it's charging, hence purple.
With secondary USB PSU: turns on, light is initially purple for 1 second, but then goes red after the cam has finished booting. So it seems that it's not charging when it's on.
So, I initially thought that the Belkin car USB adapter I had wasn't giving enough power, so I bought the griffin one (as above), but it does the same?
So I thought, since it might not be getting enough power, I used BOTH the Belkin and Griffin PSUs with a hard drive Y power cable (to take power from them both in parallel). If I'm not being clear, it's one of these things:
But it still has the same behaviour.
Can anyone suggest what the problem may be? - Is it something like needing to short out the data wires in the USB cable? - I know that most mobile phone need that to recognise that it's AC and not a data port?
Many thanks in advance for any help![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
![usb-y-cable.gif](/forum/proxy.php?image=http%3A%2F%2Fwww.hdsentinel.com%2Fimg%2Fcases%2Fusb-y-cable.gif&hash=79e07d2b42b9b8672f1a3af6d53997a5)
