- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Below some details on our new product, the first model of which we will be releasing shortly
Brand: GuardTrak
Model designation: GT2S
A few points about the design
The mount bracket contains the GPS and the 12v/24v power supply
The design gets the GPS up against the glass for the best possible reception
This also gets the camera lens as close as physically possible to the window to minimize reflections
There are no batteries inside, LiPo batteries baking in the sun are not safe, regardless of cell quality
The front facing side is all black to make it as discrete as possible
The height and width is a little bigger than a credit card, (tried to keep it as small as possible)
Using a German composite plastic that is fire safe rated, good for 100c plus degrees
Finish is lightly textured to minimize fingerprints and to avoid reflecting from outside
Because it mounts directly to the window it actually takes up less space than a lot of other models do
Basic spec
Full HD 1080p30
2nd generation ARM9 Ambarella A2 processor (USA)
Aptina AR-0330 CMOS (USA)
7 element all glass lens (6 Glass + IR cut filter)
Dual MicroSDHC memory (2 x 32GB, 64GB total)
U-Blox G7020 GPS (Switzerland)
ChipSip MCP memory (Taiwan)
Domintech DMARD07 G-Sensor with power save function (Taiwan)
ASAHI KASEI Delta-Sigma audio control circuit (Japan)
12/24 volt direct input
CELL=POWER low battery safety cut off module
High Definition 2” LCD display (Taiwan)
Super capacitor safety power supply (Korea)
High Density ABS+PC composite chassis (Germany)
Designed for high temperature, high humidity environments
Quick release mount bracket
Screen mounted design to cut unwanted reflection
All black design for discrete installation
Brand: GuardTrak
Basic spec
Full HD 1080p30
