Hi All,
I did try searching around, but did not find anything concrete, however hoping some fellow GT680W owners can help me!
I recently picked up the All-Black version from E-Prance, very impressed with video quality, just want to sort out the final niggle I have with GPS then I'll be all set!
I've got the GPS all plugged up, and it reflects that on the camera when I unplug / plug the GPS unit (the yellow satellite image shows and flashes).
Firstly, does the flashing GPS signal mean that there is no signal? I've had it running for a number of hours now (my commute is 1.5Hrs) however it never stops flashing. Also I can see there is a blue flashing light on the GPS receiver.
The firmware shows as "SeeZeus GT680W V2.6G" - I did try to install the v2.7G which was on here / Foxoffer, however after following the instructions, it does not appear to load.
I did the following:
- Format in PC as FAT32
- Copy .bin file to root of Card
- Load card into camera, and turn on ignition
Thanks in advance!
Jason
Thanks in advance!
Jason
