justinfromcanada
- Mar 3, 2014
- Canada
So I researched, and saw nothing but good reviews for the 0801. the only con i noticed was some firmware bugs, but the seller E-PRANCE said he had newer firmware 20131202 is what came with them.
out of the box they both worked well, was able to set settings on one and installed it in my truck. wire is ran, mount is on windshield, camera in mount, mount not plugged in yet, truck started. then i plug in the camera, and it turns on and starts recording.. like its supposed to. right?
sometimes it freezes after 4 seconds, can move camera and see the picture moving but no buttons work and nothing is recording, the record icon in the top left is frozen with w big red dot (it usually goes from small to big showing recording is in progress) and time does not move. holding all buttons will reset unit.
sometimes it will record for 10 minutes then stop. the screen is off now, and wont turn back on. led light is a dim red and nothing happens. if i unplug or plug into mount the red light comes back on but it wont start up.
sometimes i have recording files on my sd card that i cannot play, they ones before and after them play but certain ones wont work.
all the settings i make in the cameras get reset to default all the time. probably having to do with it freezing all the time.
i drive 15 min to and from work, i honestly cant get one good trip out of the thing. all i see are good reviews but i feel this is the worst piece of technology ive ever encountered!
the second camera worked exactly the same way. nothing but problems. freezing, not turning on. the video quality is great, and i like how the camera is supposed to function. it just is not reliable at all. in the least. i just wanted a camera to install in the truck and forget about. then go back to if something happened feeling assured the footage is there. i find myself looking at the camera every minute to make sure its still recording, which it usually isnt.
any help??? using a class4 32gb card, i read somewhere these cams dont like high speed cards... maybe its the card causing these probelms i only thought of that just now... not getting IO errors or anything.. any help is appreciated, thanks!
