Tested my Mobius cam and it is fine in the day, but night footage was very grainy and lights were causing autoexposure to go crazy.
WDR was on, should i use the low light setting instead?
Firmware is 1.20
Some people prefer the unnaturally bright and grainy low light recordings so they can 'see' in the dark ( camera at its limits). The RC people do not have 'grainy' issues to contend with. Use firmware 0.47 and I think you'll be happy with it.
WDR Low light seems much improved in the new version.
it's a trade off to be able to get more detail, really being able to see is more important than how picture perfect it looks
All the firmwares after version 0.53 have poor/noise low light performances as a "dashcam" - that's a fact.
Not a fact. The facts are available for all to see at http://dashcamtalk.com/forum/threads/night-2-b40-a118-vs-panorama-vs-mobius-b-vs-mini-0803.6312/ in which Mobius acquits itself very well against more expensive cameras, while using v1.17 with WDR enabled at Standard Data Rate.
Although you may like the old versions, there are no true facts as to which is better. Only comparisons of each, so if you please, you may use the old firmware, but saying everything after that is worse as a fact is simply not true. The newer fw brings many features that some may use, and also fixes issues that many have been dealing with. Of course there are bugs as with any release of a program or such, but in time they will surely be fixed. Also since step 3 seems to be the last major firmware upgrade planned so far, by the time its completed I imagine it will be very stable and polished.
Mobius with firmware versions 0.53 and lower would have been better than all the above !
The developer has been tweaking the low-light performance ever since the low-light parameter was introduced. V1.20 (v2.10?) should have the best low-light performance. The low-light parameter has been specifically tweaked for dashcam use, i.e. license plate readability. There has not been any additional low-light tweaking done since v1.20, but there may be an issue with the new codes from Novatek which are linked into v2.10. The developer is currently checking this. If possible, links to raw material (not youtube) should be posted so the developer can analyze the clips. Two simultaneously recorded clips using v1.20 and v2.10 to prove the fact would be ideal!The response in post #15 was related to the low light performances mentioned in post #14. Yes, the fact is very true.
