DIY Magnetic bracket mount holder instead of 3M tape
niko
Retailer
Dublin
Ireland
NB!
ANY DIY MAY VOID WARRANTY OF THE PRODUCT !
ACT ON YOUR OWN RISK !!!
There are many dash cameras out there ( mostly Korean make ) that are using double-side ( 3M ) tape to mount them permanently to the windshield, which is not that practical.
Here is an idea how to convert them into removable, quick attach / detach.
I was using fridge door seal magnetic stripes. Also tested before few other special magnetic tapes ( thin and thicker ones ), but they were not as strong as fridge door seal magnets..
Hope my idea will be useful for you or even manufacturers to change their approach to use de-touchable solutions instead of permanent ones.
P.S.- I used white colour double side tape to attach magnetic stripes to the plastic mount and to windshield, but black colour double-side tape would be preferable.
Below are photos of Panorama2 and iCaro B4 dash cameras test.
Interesting idea.
One question, do have any interference with GPS antenna or gyroscope from magnets?
Gyroscope is highly sensitive for magnets and electro magnetic interference.
Also it may interfere with e-zpass (tag to pay tolls on paid rounds in USA)
Zuntax said:
Interesting idea.
Because fridge door seal magnetic stripes are relatively weak compare to standard magnets ( but still strong enough to provide good hold even driving on high speed over ramps /bumps etc ), - there are no interference with in-car multimedia system GPS antenna ( which I have hidden under top liner close to rearview mirror ). Also did not get any problems with smart-phone GPS or eFlow tag ( same as e-zpass in USA ). Never tested with Gyro, but I assume this will not affect it as well.
Best way if you try yourself in your car regarding Gyro. It fairly simple DIY project and can find old fridge door magnetic seals in household or other places ( repair shops / recycle places )
niko said:
Zuntax said:
Interesting idea.
I was talking about GPS inside dash cam.
Also what about G sensor.
I will test that tomorrow by just adding fridge magnets to my ls400w and then fridge magnets to GPS / smart phone.
In addition will test same option with magnets from hdd.
I will also In order to be safe)))
As you can see from pictures my Panorama2 dash can gps antenna is 3mm close to magnetic pad on the widshield and had no problem. Also a g-sensor sensitivity is the same, so all devices / functions works without any signs of interference.
Not sure about magnets from HDD, never tested. But you try and let us know.
I've used "3M Dual Lock Reclosable Tape" affixed to the windshield with very good results:
http://www.3m.com/product/information/D ... tener.html
It's a kind of "industrial velcro" and allowed to share the same DVR among different vehicles, and is much more resistant than dual sided tape.
I'm trying to research on the strongest magnets I can buy that are still able to be cut/trimmed for my Polarization lens DIY project. How strong are the ones you used? Any ideas? viewtopic.php?f=31&t=2343 (scroll to the bottom)
The strongest rare Earth-made magnet is Neodymium.
You will find big range here:
http://www.aliexpress.com/premium/neody ... 0830215926
Brows through them all and find 2pcs that will match your lens casing, something like this:
http://www.aliexpress.com/item/1pcs-Cou ... 04802.html
But I dont know how this type of magnet will affect dash camera performance. I would rather stay away from Neodymium.
You may also try to use square magnetic "stickers" that you put to the fridge door, - you know ... those different pizza advertisements, etc., - just cut two similar pieces like shape of the washer matching size you need.
Or you can check if this ready made CPL filter suits your dash camera lens surrounding:
http://www.aliexpress.com/item/Mini-sti ... 61882.html
more pictures here:
http://item.taobao.com/item.htm?spm=a23 ... tive_new=1
I think I'm going to just get the 36mm MagFilter.
https://www.amazon.com/gp/B0093YC6ME
I't slightly bigger but it's what the other guy is using on his BlackView plus it will fit my Pansonic DMC-ZS30 super zoom pocket camera as well.
viewtopic.php?f=6&t=2321#p23953
If I do need magnets this site has every site shape and power
K&J Magnets
http://www.kjmagnetics.com/
I still have a cheap eBay CPL on the way, so I might use that on a future rear dual camera or something. (and will need to make another custom ring, possibly magnetic)
The dashcam in the video has a simple plastic base. With the Lukas 7900, the base houses the GPS and the antenna. If the two sheets of magnets are conducting, they may partially block the GPS signal path to the antenna. I have not confirm it (anyway to view the GPS signal level?) but please be aware that not all cameras are the same.
As for the magnetic base, it's a great idea. If you can hack the 12V contacts as part of the magnetic base it will be even better.
Did you use the same strips also on the glass side?
As I understood, you have a Lukas LK-7900 with gps bracket, right?
Its the standard Lukas 7900. The camera body is attached with a pivot screw to a thick base that contains the GSP. It also comes with a simple clear plastic mount that you stick to the windshield and that can accept the base with the GPS.
OK, I got it now.
Yes, I used same magnetic strips on oposite side ( on the glass ) as previously mentioned.
