Need a heat resistant 140 degree viewing angle cam
Milamber
Vantrue Nexus 4 Pro
My wifes dashcam needs replacing for the rear of her vehicle, we are after a camera that has very high operating temps with a decent viewing angle (140°+) Allt he cameras I have reviewed sadly dont cover this other than VicoVation which is not the look we are after for rear dashcam.
Re: Need a heat resistant 140 degree cam
how much of a rush are you in?
I can probably hold out for two weeks.
ok, too soon or I could have something you could try, won't be that quick unfortunately
ok, too soon or I could have something you could try, won't be that quick unfortunately[/quote]
Well, I could swap my camera around and give her your cam that I use at the rear of mine. What are the specs and design, is it worth me holding out?
The Lukas LK-7900 has good heat resistance but may be too big for what you are looking for. The Mini 0801 might be an option given its small size, but it is too early too tell if it is a trooper in very hot environments.
might be a bit long but I have a dual cam unit we're working on that would exceed your needs
I wonder where I can get info on operational temps.
Just to clarify: is it celsius or fahrenheit 140 degree ?
Ah my bad 140 degree viewing angle with temps of 70 degrees centigrade.
Ta
