Gil said:
Then why does it states: For DR500GW DR400G-HD 2 DR350 DR380-HD.
Isn't it because these cameras have different power specifications?
2nd question, I posted a message 2 days ago that I will soon replace my car dvr as soon as there will be full HD front and rear camera with good quality at dim lighting. So if I to purchase this Black Box Power Magic Pro, will that be usable then?
P.S. - If I buy this:
http://www.ebay.com.au/itm/KEMO-M148A-B ... 3a76b3d576
Then that means more messing around with the camera charger cables, isn't it?
So this one has a built in battery and the one above doesn't?
Start to get confusing...
Neither have a built in battery They only stop the battery going flat by having a preset cutout to turn it off at a set voltage. The power magic is adjustable as to what voltage and how many hours the parking mode will stay on for
You can use a Power magic with any camera PROVIDED YOU USE THAT CAMERAS CIGGY PLUG LIKE THIS ONE in REPLY 2
The reason being that most have a step down power supply to about 5 volts and if you hook the wires up to 12 volts you will stuff the camera I have 2 Blackvue cameras One front and one rear. My DR500 is actually running off the cable from the 400 I used to use as they all run off the same voltage and current draw.
I run the front one off a ciggy socket as shown earlier direct off a fuse I have the power magic wired to allow parking mode on the rear camera. No point in having it on the front camera as usually its the rear that would be sticking out in a park. The only difference Between the Power Magic and teh Pro is the Pro has a switch to turn Parking off if you dont want to use it sometimes.
I just wired a little switch in the line and saved some money LOL
