Mouse DVR
Mouse DVR
Mouse DVR
The Mouse DVR is a Chinese dash cam that records 1080p at 30fps.  The video quality during the day is very good but night quality is  below average.  This camera is based on the popular Ambarella A2S60 processor.
Mouse DVR Ambarella A2S60 Processor
When this camera was released, it became popular due to the very good video quality particularly during the day.  It utilizes a high bit rate, typically 14Mbps.  This is much higher than the 8Mbps in comparable A2S60 cameras such as the F500LHD and F900LHD.  Note that the manufacturer recommends using a class 6 SD card for this camera since class 10 cards often have problems.
The Mouse DVR does not have GPS or a G-sensor.  This dash cam is relatively large in size as can be seen in this comparison picture with other dash cams.
Mouse DVR Size Comparison
Top row left to right (GS600, DS103, F900LHD), bottom row left to right (F500LHD, Mouse DVR).
Unfortunately, this camera has been plagued with problems making it a poor choice for a dash cam.
Mouse DVR Models
While this camera has been nicknamed the “Mouse DVR” due to its resemblance to a computer mouse, it is sold under a variety of names.  Note that the primary distributor (perhaps manufacturer) appears to be Givoe Technology.
  1. 244/2022
  2. A2
  3. ProCam ZX5
Lines on the video
Numerous users complain that their videos have horizontal lines running through them.  These lines are typically red or blue as seen in the pictures below.
Mouse DVR Red line
Mouse DVR Blue line
Givoe has provided instructions on how to correct this problem.  You will need to solder the red wire to fix it.
Blurry Picture Quality
Some users complain that the camera has blurry or wavy picture quality.  The picture below shows an example of the blurry picture quality on the left side.
Mouse DVR Blurry
In some instances the video is wavy like this example.
To fix this problem, the lens must be replaced.  Givoe has provided instructions on how to replace the lens.
Poor Build Quality
Many of these cameras have poor overall build quality.  Loose screws, poor battery contact and rattling parts have been noted.  Some cameras appear to be fine while others suffer these problems indicating a quality control issue.
Camera Hangs
Some users complain that the camera freezes or hangs occasionally usually when it is starting up.  Not all cameras are afflicted with this problem so this is likely a quality control issue.
Mouse DVR Mount 1
Mouse DVR Mount 4
Mouse DVR Mount 3
Mouse DVR Mount 2
Mouse Internal 1
Mouse Internal 2
Mouse Internal 3
Mouse Internal 4
https://www.youtube.com/watch?&v=rOLF_9krDwQ
Even though this camera has very good picture quality during the day, the large size and the number of reliability problems with this camera, makes it unattractive.  We do not recommend purchasing it.
There are numerous known firmware versions that have been sold:
  • A04E13P0110111
  • A04E13RO110111
  • A04E13R0110915
  • A04E13P0111230
  • A04E13P0120105
Versions of the A04E13R0110915 are available:
Latest version:
Older versions:
Givoe has also released 2 firmware versions for this camera (one for the cameras with a built in memory card and one for the cameras without a built in memory card).
Instructions to update firmware can be found below:
SpecMouse DVR
ModelMouse DVR
Release DateAug 2012
SpecMouse DVR
ProcessorAmbarella A2S60
Screen Size2"
Battery Type1000mAh
SpecMouse DVR
Parking ModeNo
SpecMouse DVR
SD Card TypeSD
Error NotificationNo
CMOSOmnivision OV2710
Bitrate14.0 Mbps
Viewing Angle132°
Dimensions115 x 65 x 38
Day Video 6/10
Night Video 4/10
Reliability 2/10
Discreetness 2/10
Value 8/10
Support 4/10
