MikeM
- Mar 5, 2014
- United Kingdom
- Mini 0801 non gps, non internal mem
Hi
I have search for answers but I'm a bit lost what/where to start.
I have had my 0801 for a few months now and I still have a problem with the camera not over recording files when the sd card is full.
The camera came with the firmware 20131026 and when the sd card was 3 quarters full I got the io error messages and slow card reader. I read up on this ( on here ) and did an upgrade to this firmware 20130924 which has stopped the io error but this weekend the same has happened again, slow card.
After reformatting the sd card,(card wiped all files) the camera records as it should, no issues, travelled about 100-120 miles, no problems, a week traveling to/ fro work, and yesterday the card is now 3 quarters full, again the slow card has appeared.
The sd card was tested and found to be ok, I reduced the gig to 1g to see if the camera would over right, which it did, I increased it to 16 gig to see what happens, but alas same failure.
question is-
Will the 20131230 ( or even the 20131202) update firmware sort this over righting/deleting old files ?
should I change my sd card?too which one? I have read on here experiences of sd cards, which made me go Samsung route.
The camera has been recording fine as it should with no issues with the sd card when up to 3 quarters full.
I have the 0801 non gps, non internal memory from eprance Amazonuk and use the Samsung class 6 32g card and on full HD, 3min loop files with audio on, which is also from Amazonuk.
Hope someone can put my brain at rest as not sure what firmware to up grade to, I think its 1202?
Apologies for the long first thread, be easy on me ;-)
Mike
question is-
Mike
