Hi
I have a "genuine" 0801 Ambarella A2S60 (1080P) with GPS tracker base which came via AliExpress last year and was supplied with a "KingMax 32Gb HC Micro SD Class 10" memory card. The DashCam has firmware version 20130913 and all the genuine features /menus/ box as per "How to spot a fake 0801" article.
The 0801 has worked pretty well but the supplied "KingMax 32Gb Micro SDHC Class 10" memory card caused the known "slow read" error and stopped so I changed it for a "Micro SD HC 8Gb Class 4" which has worked but has limited record time before over-writing. Having read quite a few posts on our forum in regards to the best SDHC card to use with 0801, so today I've bought a "Kingston SDHC 32Gb Class 4" to give me more record time for my longer journeys.
Now when using the "Kingston SDHC 32Gb Class 4" the 0801 on turning the ignition on, boots up to the "Car Icon" screen, it starts to record with the blinking Red /Blue LED and the battery charging, it finds the GPS satellite OK, but after a couple of minutes it pings and the LED goes permanent blue. The OK button or other buttons are non functional and will not return me to the main screen. If I then press the large On/Off button on the 0801 it closes down and re-boots up to the "Car Icon" screen again, goes into the blinking Red /Blue LED' Record Mode' and functions 'normally' from that point forward.
Can any member please throw any light onto what is causing this initial shut down. The 0801 is cool so it's not overheating. Everything in my 'book' points to the firmware possibly not liking certain memory cards, but I'm not sure on that one hence the need of help.
Any suggestions are obviously welcome,
Cheers for now,
John
Cheers for now,
John
