My 2005 does. I tapped the switched radio wire to get a switched cigarette lighter socket. If the circuit gets overloaded the radio will stop working immediately when that fuse blows. A non-working radio is a great way to be informed that your dash cams are not working.Way back, when I messed with car stereos, there was a wire that was used to power the stock radio (it was hot only when the ignition was on).
Do cars still have that? Maybe not -- so many electronic gizmos that it's probably buried.
i have one of these, OCDTronic sent me one for review. I tested it in my work truck which has always on ports. it works great.Maybe one of these, that will also give you more options t o plug stuff in.
https://www.hiniko.com/index.php?route=product/product&path=166_169&product_id=405
As i recall it have build in timer to combat always on cigarette plugs, and also manual power on / off
@niko can advise before shopping
T | 12V Cigarette charging cable? | Dash Cam Discussion | 0 | |
V | Cigarette light adapter won't work | Dash Cam Discussion | 1 | |
D | 2 way cigarette lighter adaptor | Dash Cam Discussion | 9 | |
K | DC cable with USB end instead of car cigarette socket | Dash Cam Discussion | 1 | |
UK mains to cigarette socket | Dash Cam Discussion | 4 |
