If it doesn't boot you can't load another firmware, there's no PC software like there is with some other chipsets
How did you brick it?
The "old" Novatek G1W-H's could be unbricked by re-installing any compatible firmware. If you don't have the original or a compatible firmware, then bin it.I think the firmware I tried to install is not compatible with my version. That or I hit the power button too soon... though the light was red.
When I was testing the different firmwares in my G1W-H I tried some that weren't compatible and the camera also didn't boot up, but it only took putting a compatible firmware on the card and doing the process all over again to unbrick the camera.it need to get to the bootloader to get anything to install, sounds like he's not getting that far
I have not had that problem,but have you tried pushing the reset button with a pin next to the HDMI socket.Any method of recovering a G1WH-T after a failed firmware update? Any suggestions will help.
See? Even though the chipset is different, they can always be unbricked if you have the right firmware.Lately I tried to use a capacitor firmware to my G1Wh-T and it didn't boot up. I rolled back to my a bin file firmware i found on a Polish website (I think this is the latest one for the GPL Chip in the H series). And the cam was getting back to a life again. If you are interested in, I can share with you this bin file to give it a try.
That wouldn't work with the G1WH-T because it's not compatible with those firmwares. Different chipset.Had a moment where I thought I bricked the G1W-H but it came back to life after flashing with an older valid firmware renamed as FWDM800H.bin.
Totally agree! it WILL NOT.That wouldn't work with the G1WH-T because it's not compatible with those firmwares. Different chipset.
