Sunny
- May 31, 2014
- Colorado
- More than I can review. ;)
Here are product pictures. Both G90 and G1WH are from Gearbest.com
I have the car charger and mount in car so they are missing here.
G90 on top of the box.
Specifications on the box.
Now I get why the battery doesn't last too long.
It's useless to use as a still camera outside the car as it only lasts few minutes on full charge.
If it has less than half battery, it just shuts off as soon as it turns on..
It only has 180mAh battery compared to 500mAh on G1WH that lasts longer than 5 minutes.
Side view of the box.
Size comparison of G90 vs G1WH:
Check battery levels.
Both have almost full battery.
Just after few seconds, G90 battery is almost gone while G1WH battery is still at the same level as before.
Not sure if it is the case with all G90.
Lens module is much deep/tall on G90 than G1WH.
I wonder what's in that much space. Hmm...
But the camera body of G90 is thinner/slimmer than G1WH so that makes the G90 lens look like it's protruding out too far.
Top view of G90 and G1WH.
G90 lens has much wider view.
As you can see, lens on G90 is actually coming out of the module while lens on G1WH is completely inside the module.
Need to be careful not to scratch G90 lens as it comes out little bit.
Bottom view of G1WH and G90.
