Mtz
- Nov 15, 2012
- Nice place
- Romania
- Viofo A229 Pro TeleQuad (the best dashcam in the world!)
The DashCamMan review is there. But here you will find a little more information and feedback which is not necessary to be included in a review.
My Livue LB100 just arrived after 6 days from South Korea after placing my order to lightnspace from ebay.
In fact you are buying the WinyCam V300HD which is the english version of the Livue LB100, but the case is different and the Winy costs a little more in UK, maybe because of EU taxes. I think Livue just realised that WinyCam have a not commercial case and just made it in their own style.
Pictures:
Look HERE for more pictures
Unboxing:
Different mount systems: first cameras were delivered with the ball mounting system, but the actual are with the vertical adjustment one.
Comparison with Itronics ITB-250HD:
Software:
- Android application named WinyCam V300HD
- english viewer (use the normal, not the New Viewer because it create wrong setup.cfg file)
- SD Card: Manual, firmware, default configuration file
- the firmware filename must to be WINYCAM_V300_yymmdd.bin , for example: WINYCAM_V300_121115.bin
- on the WinyCam website you can find a newer firmware.
- if you want to use the korean firmware you must use the Livue PC software or Livue Android application, all being in korean. For the camera sold on ebay you must use the WinyCam software if you want english
- If on the bottom-right screen you will see V300HD, the firmware installed is the WinyCam, but if is FW01, the firmware installed is the Livue
- the description of the setup.cfg file
Hardware:
- chipset: Core Logic (Lucy) CLM550F2 made in Korea
- lens: TCBW A203_2M_1/3" (unknown?)
- manufacturer: the camera is made by WinyTech
Operation:
- How is working the LED. Video. The LED can be turned off.
- How to format the card using the camera big red REC button: take out the power cable and wait the camera to turn Off > press and keep pressed the REC button and insert the Power cable > after the Power LED is blinking and the voice will announce you the card is formatting, release the REC button and after max. 1-2 seconds press it again for very short time.
I like:
- have the Power saving features inside firmware. You are nor forced to buy an expensive Power Magic, or UPC because you can set the same things in camera preferences
- a lot of settings. even you can adjust the camera sensor settings
- the mount even is stuck, the camera can be removed from it. You need to use both hands, but is easy and if you are in some area you don't like is better to take the camera with you
- the voice option is nice
- you can turn off the LED so you don't need to cover it with some tape. So easy and smart compared with many other dashcams including Itronics
- the GPS antenna (if ordered) is included in the mounting system
- a lot of vent holes so the camera will cool
Don't like:
- I think the camera is in 60HZ only, so for 50HZ countries is possible some flickering because of city lights
- not full black. I like the Itronics black matte style. Even the Livue is black, it is glossy. And the lens mount is gray. Why? But better than pink or white WinyCam
- the LED is very nice, bu stupid because of reflecting in the windshield, in parking mode the LED is possible to start the recording not just stay in stand by. Lucky, we can turn off the LED from the software applications.
- too sensitive white balance which cause "jumping" colors
- no Mute button
- my lens were blurry on the left side. The seller fixed the problem for me.
Problems:
Loop rebooting: if the camera is trying to start and during this time the Power LED is blking 3 times (while the REC LED will be ON) and the restarting again, you must to take the card out, insert in some PC and delete the file named reboot.txt
In that file is something like: [8] Tue Apr 2 19:08:46 2013 [8] Tue Apr 2 19:08:56 2013 [8] Tue Apr 2 19:09:06 2013
The solution is to format the SD Card how it described in the manual or to try to use another card if the file is created again.
Some pictures about this camera:
enjoy,
Mtz
Pictures:
Unboxing:
Software:
Hardware:
Operation:
I like:
Don't like:
- no Mute button
Problems:
enjoy,
Mtz
