Hardwire cable question
limke89
Brisbane
Hi my previous Blackvue DR750X - 2CH Plus was hardwired to my 2021 MG HS. However the front camera was damaged in an acciden. I‘ve got a new DR900 X - 2CH plus and just use the existing hardwire connection. I have refer to the compatibility chart, and from what I understand is the x series should be compatible to each other. Am I correct? Thanks heaps.
Are the male ends that go into the actual camera the same?
The existing installed cable (750) does goes into the new 900 and able to power up my 900s+. The rear camera uses the same cable as well.
Please remember that there are multiple DR900 dash cameras (DR900S, DR900X, DR900X Plus). The same is true for the DR750 series (DR750S, DR750X, DR750X Plus). I only state that since it matters which exact model of dash camera you're going from and to be sure of the cable requirements. All of the "X" and "X Plus" versions of the DR900 series (DR900X, DR900X Plus) require a 3-wire hardwire cable.
Going from the DR750X-2CH to the DR900X-2CH Plus should not require changing the power cable since they both use the same 3-wire hardwire cable (the one on the right in the picture).
Cheers.
Figures as such. Yeah, my previous was DR750X Plus and the current one is DR900X plus. They‘ll have the same connector. Thanks.
Top Bottom
