Is Mini GPS module compatible with Mini 2?
Quidagis
Colombia
I have a couple Minis in my car and would like to upgrade to the Mini 2. Can I connect the Mini 2 to the Mini GPS module?
Just keep in mind that the viewing angle of the Mini 2 is greater than that of the Mini.
If the Mini is installed too high under the silk-screen printing, then when installing the Mini 2 in its place,
part of the silk-screen printing will fall into the frame.
As here:
¡Carajo! That's gonna be a problem. If that´s so, I guess the issue will be to the right of the FOV.
Thanks @Karagandinez for the heads up.
As here:
@Karagandinez
You were right about the viewing angle. I had to move the mini GPS module on the windshield about half a centimeter. It's a PITA but it's done now.
Thanks again.
Top Bottom
