Greetings,
Recently my LS430W has stopped auto-starting in the morning when I start the car. I've also noticed that when I turn off the car, the unit turns off, then on, then off, then on ...
The final video from each trip is corrupt.
I suspect all this points to the fact that the battery is no good anymore. It can't properly shut down the unit.
Has anyone replaced a battery in these things? Do you just (carefully) pry the unit open to access the battery? Does replacing it require soldering, or is there a battery connector? Any specific recommended battery and where to buy?
Thanks!
Bill
Thanks!
Bill
