Mini0801 custom firmwares
Thank you @Tobi@s
I'll wait for a new firmware
Going forward will install only firmware custom.
That startup sound continue, patience =(
Regards
You could try this one:
Here are the custom versions (custom logo, no boot sound)
Without internal memory: http://dl.madjawa.net/mini0801/firmwares/custom/20131202-1card-logo-nobeep.zip
With internal memory: http://dl.madjawa.net/mini0801/firmwares/custom/20131202-2cards-logo-nobeep.zip
(I got the internal memory firmware from Demi, I posted the link of the original FW in the 20131202 firmware thread :) )
Many thanks to Tobi@s for the packer/unpacker :) And the logo too!
As always, it's at your own risk. But I flashed both on my cam successfully :)
I tried with old firmware:
20130924 GPS + External + Internal card card
20131026 GPS + External + Internal card card
unsuccessfully
My last update I used this name (NO1-firmware-SPI-TB15) worked to update.
For the custom firmware, i tried with all names on FAQ mini0801
I think that after the update, is not possible to install versions
prior or equal to the current.
I wait for new firmware
I sent one question to Lia on Givoe, waiting for response
Thank you so much
Regards
I just received the latest 20140115 firmware for internal and non-internal memory devices. When I'm home frm work I'll provide you a no-Sound fw.
Excelent news @Tobi@s
This firmware is for:
GPS + External + Internal card and
GPS + Internal card card
Something new for this version?
Sorry for disturbing @Tobi@s
Thank you.
Not sure yet. Gonna try it @home.
Hi Tobi@s
Any good news about 20140115?
Well.. It runs without any problem but I cant find any differences (beside the OJOCAM branding) to 20131230
But now we have an up to date GPS + External Memory Rom with ability to choose between kph/mph
Wow excellent, I guess e-prance/givoe were misinformed when the factory told them they couldn't fit any more menu options into the limited space. (glad they made MPH/KPH a choice!)
I don't like the startup sound, but I do want to hear a chime if it shuts down in the middle of driving. Have you found a way to take out the start-up sounds, but keep the shutdown sound active?
Almost the easiest thing to do ;)
Guys, the firmware version 20131230 do not show velocity on Movie?
Tips for enable?
My last firmware (20130924) Showed on movie = /
@Tobi@s
if you provide the firmware 20140115, I test.
but without startup sound / turn off sound.
GPS + External + Internal card and / Givoe
Thank you so much
Regards
@BrazilianGuy
Please try it: http://p-mc.eu/dc/dl/get.php?f=20140115-GPS-2CARD-nosound-clogo
They actually did some filesystem changes in this release. There are less unused files and less audio files. For every audio event there's a blabla.pcm and a blabla_low.pcm for a coming soon "low audio" setting probably?
Can't do the other requests today... Sorry :p
My cam no longer recognizes any firmware after 20131230
- I format SD card (fat32)
- Copy the bin.
- Rename
- I try with names:
firmware-NO1-SPI-OV2710FLIP-TB15-M8452.bin
firmware-NO1.bin
NO1-firmware-SPI-TB15.bin
firmware-NO1-SPIF-TB15.bin
firmware-NO1-SPI-OV2710FLIP-TB15-MA310.bin
- Turn on USB with cable / turn on
But do not work = (
Is there any way to force the update?
You could use a burning cable to "force" it.
For normal flashing you should use the filename "firmware-NO1-SPIF-TB15.bin" (Check if your Computer hides file extensions) and copy it to the root of the SD-Card.
Then start the Dashcam without any connection and it should ask you to update.
workedddddddddd :D
My Macbook hides some files after formating
I used the command:
- defaults write com.apple.finder AppleShowAllFiles TRUE
- Killall Finder
I deleted some hidden files, this files appear even after formatting.
Put the .bin and WORKEDDD xD
i have one problem, but nothing major
The imagem when startup / turn off bug
Thank you so much , Thank you =D
20140115 perfect works here
Thank you @Tobi@s
@Matrix, my version works on your 0801, try..
Picture startup Bug, but no problem.
Regards
@Tobi@s hi. its me again :D
Could you please prepare 20140115 for Honda and Renault with sound, with GPS, no internal memory?
Hi Tobias,
just got the 0801 and liking it so far, been pointed toward this excellent thread to get a custom picture on startup/shutdown. I haven't seen any Audi photo firmwares, so would you be able to do one for me?
20140115 + GPS + External memory + Internal memory + with startup/shutdown sound + registratorviewer + with the following photo?
http://farm4.staticflickr.com/3814/12012924213_256b506d83_o.jpg
Many thanks.
