So I finally got my Vifo A119 up and running, and I wanted to get your expert opinions on the adjustments I've made in order to see if they're optimal. In the daytime picture below, I'm curious if my cam is angled a bit too high and is capturing too much horizon and not enough dash. Does it looks pretty solid as is?
Second question, you can see in both the daytime (above) and nighttime (below) grabs that I'm getting a good amount of reflections, especially in the lower left and right hand corners. On the night shots, you can see that in very dark conditions there's large triangular black sections in the corners where the cam doesn't pick up anything, but they do correspond to the high-reflective areas seen in the daytime photos. You can see in the second night grab that once there's some light coming overhead in the right corner, the cam does pick up the image accurately.
Would the CPL filter mostly eliminate my daytime glare and perhaps some of the dark reflective corners in the night shots? Or would it only take care of the daytime reflections?
