So, I've come to the conclusion that I, unfortunately, feel uncomfortable hard wiring a camera for parking mode (which I really want). With that being said, I would like to start with a front cam which has the option of adding an additional rear cam, later on down the road (pun intended).
I am looking for the following:
Plugs into 12v
Has the option of adding a rear cam (how do rear cams typically connect to front cams?)
High definition, something that is top of the line HD in day/night/inclement weather
Some sort of screen that I can look at to ensure it is on and recording, but nothing so big it is distracting
Something as small and discrete as possible and blends in. No flashy lights.
Must be continuous recording with over writing capabilities, but saves footage when bumped, hit, or jolted.
GPS and speed isnt too much of a concern, but I wont shy away from it.
Can anyone give a reason why GPS and speed is necessary? I see a lot of talk, but feel as though the speed capturing could get you (the dash cammer) in trouble. Thoughts on this?
Oh, and price range is $150-$300 (just for the front cam), but will spend more if the quality/specs are worth it.
EDIT: Also, I would prefer a wide angle, I'm thinking 180 degrees
Plugs into 12v
