Kenco
Anyone found the Technical reason why the G1W series doesn’t work with some SD Cards.
My G1W has worked flawlessly for 11 Months on a 16GB Transcend, decided to upgrade to a Transcend 32GB (also a Sandisk 32GB) but reports Card Error in a split Second on both at power up, i’ve done several tests with different types of Software and theres no appreciable differences, all Cards are good Class 10. ( all cards work perfectly on 2 different Camcorders ).
Even copied the contents of the 16GB Card to the other two. 32GB cards to check if the problem is creating a new DCM Folder at the beginning but still fail just the same.
There should be a good technical reason from the Manufacturers as to why they are so finicky,
Great Car Cam though.
